Auxillary battery and bracket orientation
WIS has you attack this job removing the paneling over floor under dash. An alternate method is to remove screws securing fuse box to left, moving it out of way and addressing the bracket and battery from there. This could help you find the threaded insert you're looking for.
When I did mine i couldn't get the screw to thread, so i temporarily used a longer one and then vice grips to squeeze the bracket to the substructure. then removed temporary longer screw and fitted correct screw.
CL550/C216 is same as W221 ... it's the 2-door S-Class!
