Power Trunk Closing Issue
Old Nov 1, 2023 | 11:22 AM
w126w221's Avatar
1984 W126 300SD & 2013 W221 S550
Hello All,
I experienced an interesting issue the AM, during our first major temperature drop of the year. I walked out to the car, popped the trunk via key fob, and it power opened with no issue. Once I loaded my cargo, I noticed that none of the trunk lights, or back facing indicator lights were lit. Thinking it was a nonissue I pressed the truck close button and the trunk stayed in the upright position. I started the car, thinking it might be a weak battery, and pressed the button again with no luck. Channeling my inner diagnostic technician, I manually triggered the latch closed with a key, while the lid was open, then pulled the outside trunk open switch. The latch sprung open and all the lights turned on, and the automatic closing trunk functioned fine. Post commute to work, the same interesting issue reappeared, and was solved via the previous method described.
Anyone else experience this issue before? My mind defaults to sticky or sluggish microswitches within the latch mechanism. Is there a spray cleaner which could be utilized to resolve this issue and save myself the need to replace the entire mechanism and loosing $430?
P.S. I have a Mercedes XENTRY Diagnostic Scanner, but the multiplexer (vehicle to computer interface) is currently with a friend, so I can't pull codes.
Old Nov 1, 2023 | 04:09 PM
BOTUS's Avatar
S500
I would expect its snapped a wire and whilst your manual intervention magically woke it up twice, it was probably wiggling the lid that luckily got the just snapped wire to make a bad connection....
the ones I've read about and exactly like the one I worked on (although not an S class).... you find they route the wires to ensure the loom has a deliberate path making most of the lid opening movement around the hinge land at one stress razor, then cable tie it into submission very tightly, having calculated the ave number of openings over x years until it snaps the larger brown earth wire like a carrot - nicely outside the warranty period
Next time get a wire strip both ends and see if you can just make a new earth to see if the lights come on... (US seem to call earth - ground)
Old Nov 1, 2023 | 04:12 PM
Shadly1's Avatar
2007 S550
There was a nice video somewhere about how to find and repair those broken wires at the trunk hinge. I followed it a year or two ago and discovered that I didn't have any broken wires.
Old Nov 1, 2023 | 04:15 PM
BOTUS's Avatar
S500
we had one the other day, he found it inside the lid behind the trim in a bit where there is no movement of the loom - the S class electrics are a bit more special than a normal car
