AC blower works intermittently
Old Nov 26, 2023 | 04:41 PM
2011S550w221's Avatar
2011 S550
Hi all
need some advise
AC blower wants to blow intermittently
the diagram doesn't list the blower fuse or relay
there the fuse box on the driver side in the engine compartment
i shook the relays
no change
If It's the blower motor under passenger dash then I can replace but wanting some advice
thx
2011 S550 base NOT 4 matic
Old Nov 26, 2023 | 04:44 PM
BOTUS's Avatar
S500
have a search - must be posts - likely crap build up below the battery under the bonnet has allowed water to flood the blower motor
its a normal Mercedes trick
Old Nov 26, 2023 | 08:14 PM
2011 S550
AC blower
In the engine compartment where battery is?
or
under the passenger dash?
Old Nov 27, 2023 | 07:29 AM
BOTUS's Avatar
S500
under the bonnet pull out the battery - remove its mounting bracket - 2 bolts - clean the gunk up, unblock the plastic gutter pipe from edge of the screen running in to the inner wing
then pull back the carpet inside and sort the corrosion mess and puddle - then look up at the blower motor and sort that
the module to control the AC sits beside the fan - the side away from the inner wing - I believe its the connection or brushes sitting on top of the fan that cause the fan to give up - on most Mercs its at the top of the fan ready to get wet
Old Nov 27, 2023 | 09:40 AM
2011 S550
AC blower
I call the bonnet the hood
lol
Old Nov 27, 2023 | 05:47 PM
S550TK's Avatar
08' S550, 19' GLS450
Sometimes my blower motor turned on and sometimes it didn't. I replaced the blower motor and that fixed the issue for me.
