Drivers door air leak
Old Dec 13, 2023 | 01:28 PM
Cary5500's Avatar
10 s550
Anyone know why the drivers door would be making a wind sound? Door seems to shut fine and weather stripping has no obvious sign of damage.
Old Dec 13, 2023 | 01:33 PM
BOTUS's Avatar
S500
w221 ? more like your seats - I don't think you have air in the doors !
earlier Mercs did use pneumatics for the central locking
Old Dec 13, 2023 | 05:43 PM
Cary5500's Avatar
10 s550
sorry it sounds like wind coming in hissing
Old Dec 13, 2023 | 09:12 PM
vettebk's Avatar
2007 S600, 2007 Chrysler 300 SRT8, 2000 C5 Corvette, 2017 Mustang GT, 2023 300C, and a 2019 Lincoln
My S600 has a similar wind sound in my case on the passenger rear door. I changed out the weatherstripping and it is better but still not great. My solution was to increase the volume on the radio.
Old Dec 14, 2023 | 06:47 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
You could buy some weather stripping of various sizes and try adding to the existing seal. Experiment and see if the problem goes away.
Old Dec 14, 2023 | 08:47 AM
BOTUS's Avatar
S500
you should have total silence - I don't get any wind noise from poor build or bad door seals ? mine has the heat insulated IR windows that are two bits and thus thicker than normal - even so - I'd be looking for issues with damage or the doors not closing correctly - door mirrors can make noises are these fitted OK,
Old Dec 18, 2023 | 12:06 AM
Dalplex's Avatar
04 SL600/07 S65
Is there any alignment issue? Check the paint around bolt of hinge, whether it was original or freshly cracked?
