Blind Spot Probelm
I have a weird problem with the Blid Spont inoperative message of my 09 W221-S550. The problem comes when I fold the side mirror or go through a carwash.
Sometimes, when I park the car on sunny, hot days, the blind spot starts working, and it is good till I fold the mirror or wash the car. Has anyone had this problem and knows how to fix it?
Thanks.
1) If you have your door mirrors set to auto fold - the wires SNAP - it varies with vehicle use, short runs lots of stops - 50k all dead and $2000 dollars wasted or higher mileage cars <150k - you have circa 10 wires per mirror that can all break in multiple places and or the mechanism wears out
first thing I ever did when I bought mine was go in user menus and turned off "destroy my door mirrors" feature. I fold them in when I need to, its on average once every 2 years - which is far more frequent than using the useless TV function
2) the BLIS sensors 'appear' to be some weird radar confusion within the rear boot air vents (...on cars where they have this feature.) - behind each rear wheel on the inner wings, are two low mounted large air release vents (to let you close the car doors easily) they are beautifully designed to let copious quantities of flood water fill very large buckets full of electric modules, I presume to take >10,000K out of you wallet if you allow water to reach them - all perfectly hidden from view, where the spare wheel area remains 100% clean and dry
part 190 one on each side....
2218200775 W221 ANTENNA MODULE
