Suspension side bounce
On uneven or bumpy surfaces, I'm getting side bounce to the point where my head is tilting from one side to the other constantly. It feels like it is coming from the rear suspension more than the front. The car has never been in any kind of serious accident that I am aware of.
Anyone else experience this or have thoughts on the best way to troubleshoot?
Front suspension lower arms X4 are ready if not replaced recently. Front Upper ball joints are due. There are rear suspension arms that die as well. She is old enough that the dampener function of an Airmatic strut can be going away. Or is your car equipped with ABC? You didn’t specify.
It is time she visited a competent mechanic for diagnosis.
This ride height is obtained from settings in the ecu compared to the THREE level sensors fitted to the car's suspension - and the amount of air a compressor feeds to each strut - the link rods connecting these sensors have plastic ball joints these magically seize to the metal ball, leading to bending / snapping brackets and misreadings of thus strange ride heights.
if you can wobble the link rod on the ball joints by hand and the ride heights seems OK, check out the condition of the mechanical parts of the suspension... a leaking worn damper might be the issue - the air only replaces the conventional better and more reliable steel spring fitted to real cars - everything else is conventional, but as is modern business practice the rubber bushings on cars for the last 30 years are made of self disintegrating nothingness
BOTUS The feeling is like there is an unsettling of the rear of the car…like it jumps a little when hitting a bump, sometimes left and sometimes right.
The tire to fender gaps look about the same all around but I’ll measure them on a level surface tonight to see how even they are.
I’ll also pull the wheels to look for leaking/wet dampers/struts. Where are the three level sensors located?
one garage said the "diff bushes were gone", when I first got it at 42k miles, but having never done anything about it nor seen in these 10 years anything look wrong. Just last month a specialist merc indy took a look and didn't find anything - he even owns his own similar age 221 v12... all he said was my air tragic car with 18" wheels its a lot softer than his 19" wheeled ABC car
has it occurred to you the roads are now worse than most dirt tracks ever were years ago? they are where I live. or perhaps you found the S button and can feel a big difference ?
I’ll get under it with a pry bar over the weekend and look for some shot bushings or ball joints. And try to look at the struts/dampers too.
Those tires had very weak side walls. I went with Nokian zLine A/S and it made a huge improvement. There is still very little of it left but not enough for me to start working on the suspension that I first planned to do.
Check that you have enough air pressure on your tires as this is important for the side wall strength against lateral movement.
You have E-class also like I have with 18” wheels. Go push both cars rears sideways and you can compare how they bounce. Mine shoved huge difference between them that made me to change away from those Michelins.
This S-class seems to be very sensitive for this sideways bouncing and I’m quite sure it is mostly tire side wall strength related. Before this 2012 model I had the same car 2013 model with 20” wheels and in that one I had none of the sideways bouncing that I could feel.
I’m not saying sideways bouncing does not indicate problems with suspension components but at least in my car the tires quality is a big player in this.
