bad main on m275.993
Good afternoon. Tell me, I can’t find the dimensions of the tolerances for the crankshaft bed, main m275.993What is the tolerance of the hole in the engine cylinder block for the main bearing?
Don't know. When my 275 spat a main shell into the chains for bent valves I replaced the engine with a low miles used example that ran well for the remainder of my time with the car.
Short answer... It has to be tight enough to clamp the bearing shells in place. There are no locating tangs on the block or the bearings.
Did it spin a main bearing?
If so.... which one?
most of the colonies remembered how to use English - where a thousands separator is a (,) aka 1,000 And the decimal point uses a "." as in 1.00 - if the world meant us to use a comma it would be called a "decimal comma" but its not
using a comma in the wrong place, is another of napoleon's habits to try and be different - like driving on the wrong side of the road. Picking a different idea is fine where the reason is to improve things, taking us backwards is self explanatory.
The best bit one nation sticks to its guns better than most (the bloody french again) but even they set their computers to English language settings when doing any real work....
even the Zionist's enemy gets it right “Пожалуйста, запишите число 0.5 с использованием десятичной точки.”
Senecat (04-21-2024)
BOTUS (04-20-2024)
