2007 S550 🥺🥺
without catastrophic failure of engine or gearbox the rattle doesn't makes sense 9and a catastrophic failure of these is also rather odd for a car that's done nothing
when it drove aside from the noise, did the engine power and gearbox behave as you remember - or was performance and gear changes impacted ?
could be noise from other components making the noise
is it a 4 wheel drive version - will say 4matic inside or on the boot ?
ABC suspension ? this can leak and make funny noises - its an optional higher spec suspension system so me had
PAS steering pump noise?
Perhaps the Alternator / PAS / AC / Water pump drive belt idler bearings self destructed and the leak it from the belt flying around and damaging something
if your skills aren't enough to take a look, you will need to find someone... merc interdependent's are used to crazy cost jobs - they shouldn't rip you off - all Mercedes from the last 20 years are so unreliable they have no time to rob you - the queue round the building gets longer every minute - and they can't even spend all the money they make as there isn't enough time in the day
the fact you say it doesn't move and you have strange noises, is now making me think your torque converter has blow its brains out - plug in some diagnostic gear and see what it says
in the UK main franchised dealers need to pay the 10m annual lease on the building and rip off salaries for the 10 sales guys and their bonuses - the real workers are on min wage - but all that means $400 lab cost to the customer for servicing, where the indy garages charge $150 an hour - but the real benefit comes where the interdependent ones have actually seen all the faults and fixed them - where as the fully trained franchised dealership only know where the bonnet release catch is (and a jet washer)
before the initial issue when the last time I drove it there were no issues or oil links and the belt was changed in November of 2023 and the car was rarely driven after because of work schedule and I have other vehicles, it's basically a weekend car... thanks for your reply and I'll keep updating the thread once I find out the problem
