Help with Codes 14b100 & 1a2600
did you leave the wires off a coolant pump
https://autonevod.com/obd2-codes/p2600
https://autonevod.com/obd2-codes/p2400
https://autonevod.com/obd2-codes/14B100
https://www.obd-codes.com/14B100
great some moron invented a newer version of events that most of the internet doesn't understand - but still has a P at the start
OBD2 Code P0101 https://autonevod.com/obd2-codes/p0101 = UDS
P100700 The upper limit value of component 'B2/14 (Hot film mass air flow sensor)' has been reached.
P100900 The upper limit value of component 'B2/14 (Hot film mass air flow sensor)' has been reached.
P101700 Component 'B2/7 (Right hot film mass air flow sensor)' has a plausibility error.
P101900 Component 'B2/7 (Right hot film mass air flow sensor)' has a plausibility error.
P14B100 Component 'B2/14 (Hot film mass air flow sensor)' has a plausibility error.
P14B200 Component 'B2/14 (Hot film mass air flow sensor)' has a plausibility error.
P150100 System 'Charge air' has a malfunction.
P150200 System 'Charge air' has a malfunction.
P150300 System 'Charge air' has a malfunction.
