bad ISM or EIS
Old Jun 24, 2024 | 12:19 PM
symbolic95's Avatar
1994 S320 / 1984 300sd
bad ISM or EIS
Have been battling starting issue for awhile , if car is left unlocked - no issue , locking the car will cause the non starting issue - clock stopped at the time when possible faulty module shuts off , would not crank , no car milage displayed , solution is to disconnect the battery for 10 seconds .
Below are the fault codes from EIS and ISM modules.
Has anyone encountered similar problem?
Old Jun 24, 2024 | 02:11 PM
BOTUS's Avatar
S500
how about clear all faults.... get fault, check error, disconnect battery see which fault is no longer active
Old Feb 4, 2025 | 07:37 PM
colandreo's Avatar
Did you ever solve this. I had the SAME exact problem and it was my EIS.
Old Feb 5, 2025 | 04:16 AM
BOTUS's Avatar
S500
Mercedes ignition switches give up all the time
