No crank issue
Before another blind blast of the parts cannon do some real diagnosis. Do you have a test light? You need one that uses an incandescent light bulb. Preferably one such as was used in a dome light for a Mercedes in the 1970s. ‘Test probes’ that have digital volt meters or LED’s will lie. An incandescent light bulb will draw enough amperage to say ‘Yes, this circuit may even be able to trigger the starter.’
Is there 12 volts to the big lug on the starter? Is the signal getting to the small wire on the starter which tells it to crank?
Are grounds between engine and chassis intact and tight?
