d241 error SDAR antenna
My sirius XM satelite quit working and their tech support could not cure.
DAS shows this code: "D241 The antenna cable from the component N87/5 (SDAR control unit) to component A2/82 (SDAR antenna) has an open circuit."
Has anyone else had this and fixed it?
WIS says tear the trunk inside panels out and replace N87/5, hoping there is an easier solution.
Thanking you in advance!
you could try a cheap aftermarket antenna as germany have no clue how to make these work even when new
tuner sits in the left rear wing near the tail light - trim remove is OK... once you have battled the ridiculously mounted plastic trim panel across the back of the car - all the clips will break and its mounted more securely than the from crash structure of most new cars
four or so out there under $60 - make sure you have return policy as they DIE
https://www.ebay.com/itm/126645910213?
