Possible trans slip
2008 s550 4 matic 120k miles.
I feel like there is a slight hick up from 2-3 shift at light throttle. its like a little uncertain stumble. Only at light throttle. Otherwise its fine in all other gears. And its fine if I apply more than 30% throttle input.
Friend at MB hooked it up to MB system it it didnt show anything bad. The clutch wear was at 800 I believe out of a 2000+ or- Range. He assures me that is normal wear for the miles.
I have MB records for the car from new, 6-8 pages, in it there are no records for trans fluid change. I cant decide if its a good idea to change fluid at 120k miles. I am afraid of things getting worse after it and not better.
Naturally I dumped thousands of dollars over last 3 years, $2000 just this summer and would like the car to last another 30-40k miles as I barely drive it, weekend car mostly. Id hate to dump another 4-5k into it if trans goes. Car is mint otherwise.
Advice is appreciated.
Thank you in advance.
they pretended its was fill and forget and they dropped like flies way before end of warranty
they moved to a one off 42k mile change
that wasn't enough and it moved again to every 37 k miles
if u have filth destroying your box get it out
pretending swarf and sludge is better is insanity
double check what they do with 4x4
Change your fluid before you destroy the clutch disks packs inside the tranny.
