2009 s600 engine sound louder after 25 minutes driving
Old May 27, 2025 | 11:23 AM
johnny_3352's Avatar
w221 s600
Hi folks this could potentially be a very stupid question, but I got this interesting symptom that I'm not sure if it's a cause for concern or not. After around 25 minutes of city driving, pretty reliably, the engine bay suddenly sounds louder. When engine RPM goes up you can hear very obviously a whining sound goes louder. It was not like this in the first 25 minutes during which all sounds are pretty well insulated.
I'm guessing at around 20-25 minutes mark some additional pump starts to run (whose speed is proportional to engine RPM) or turbos behavior changed, and that sound is not well insulated? I don't notice any other difference other than the sound. What could it be? Thanks!!
Old May 27, 2025 | 12:15 PM
Jaap's Avatar
2006 W221 S500L M273
Can you make a video of the running engine after 25 minutes of driving?
Take it from different angles - someone may notice something weird.
Old May 27, 2025 | 02:07 PM
BOTUS's Avatar
S500
the only thing I can think of is the cooling fan - on full chat that can make lots of noise
have you checked the level of the charge cooler.... that likes to loose coolant
Old May 28, 2025 | 10:37 AM
JohnLane's Avatar
222 S-65
OP it will be equipped with ABC. The nitrogen bomb (pressure dampener) that threads into the duo-pump may be losing its nitrogen and making for noise. Ten minute repair.
At idle as it makes the noise.... long screwdriver applied to A/C compressor, Duo pump, alternator, behind each of the bearings in accessory drive...
Find it.
Old May 28, 2025 | 07:40 PM
w221 s600
thanks for the advice! will check the fan and abc nitrogen bomb. will also try to get a video.
