2010 S 550 Battery
Old Jul 28, 2025 | 09:27 PM
bohaiboy's Avatar
2010 S 550
2010 S 550 Battery
We left on a trip and the car was in the garage for about 30 days without starting. We returned home and it started just fine. The next day, the battery was dead. Had to jump-start it. The battery level was down to like 3V. Performed a tickle charge overnight at 2 AMPS? Next day started fine. A few days later nada on the start, recharged again. Note battery was at 12.8 v after re-charge. I disconnected the battery terminals and left overnight. Reattached the next day and car started fine. With car running, v=14.x, so the alternator appears good. Car is now sitting with the battery terminals connected and V-12.5V. Will check again tomorrow to see if there is a parasitic draw somewhere.
If there is a parasitic draw,. any suggestions? I have tried to make sure any thing that could draw extraneously is unplugged, radio in off position etc. How hard is it to track a parasitic draw? Please note, the 2010 S550 only has a main battery under the hood, not in the trunk. There is an auxiliary battery located behind the steering wheel area. Note car has 164K miles.
Old Jul 28, 2025 | 11:11 PM
streborx's Avatar
Top Answer: 1
G550
How old is the battery?
Old Jul 29, 2025 | 12:00 AM
bohaiboy's Avatar
2010 S 550
Originally Posted by streborx;[url=tel:9194253
9194253[/url]]How old is the battery?
about 3-4 years old. Mechanic did not punch a date out
Old Jul 29, 2025 | 08:48 AM
streborx's Avatar
Top Answer: 1
G550
I'd have the battery load tested at an auto store. Batteries can begin dying at any time (my OE battery died at 42 months). A bad cell can drain the battery just as a parasitic load would do.
Old Jul 29, 2025 | 08:08 PM
Alexie's Avatar
To find a parasitic draw, wait 20+ mins for the car to sleep, then check the current with a multimeter should be under 50mA. Pull fuses one by one if the draw drops, that circuit is the issue. Common culprits: glovebox light, faulty modules, or the aux battery. If unsure, a shop can help.
Old Aug 10, 2025 | 05:00 AM
Vinnie P.B.'s Avatar
MB S550 2008 4MATIC (V221) M273 412Hp
Just buy and install a new 1, return the old for recycling.
