Starter only cranks when starter relay is jumped
Old Oct 26, 2025 | 06:55 PM
clb0099's Avatar
‘16 Mercedes GLE450 amg,’15 Mercedes gla, coupe,’07 Mercedes w221,’12 Audi A
Yes, one is the starter batter in the engine bay. The rear battery is for all the main electrical stuff in the car. Both barriers tested and are good. Even tried putting jumper packs on them and still not cranking or starting
Old Oct 26, 2025 | 07:17 PM
BOTUS's Avatar
S500
Originally Posted by TimC300
Not sure if this was mentioned but aren't there two batteries in the W221? I see two in the starter wiring diagrams.
early cars get two big batteries - mini facelift in 2008 moved to one bigger one up front - but some still seem to get two till 2009 - then they get a baby one behind the ignition switch which is to power the ISM when things have gone wrong with big battery, I guess to enable you to be able to easily push it into a ditch
Old Oct 30, 2025 | 09:12 AM
clb0099's Avatar
apologize for the delayed update. On Tuesday, ninjabenz examined my vehicle and determined that the new ECM key starter enabler was not activated. Last year, I purchased two ECMs from an overseas supplier, who programmed my VIN into both units. The ECMs, which are Bosch branded and feature the latest part number, came with a three-year warranty, so I will be contacting the seller. Currently, the vehicle starts and functions as intended.
