Pump keeps stopping when filling with gas
Old Nov 13, 2025 | 01:49 PM
Billydv1's Avatar
2011 S550 4matic
So, this seems to be a common problem, covered already, replace the charcoal canister in passenger side rear wheel well. I opened mine. What i found was the purge valve simply twists out. The foam sleeve was completely dried out and crumbling. I cleaned the filter that sits below it, brake kleenex and compressed air. Blew through all the cubes, making sure this was able to breat. I would have replaced the foam but had nothing to replace it with. Put it back together, works perfectly. Wish I could source the foam sleeve but seems to work without it
Old Nov 13, 2025 | 02:13 PM
BOTUS's Avatar
S500
should have checked / added to the other recent post
https://mbworld.org/forums/s-class-w...e-filling.html
