w221 window goes down only few inches at time
I have a w221 s_class 600 2008 they only go up and down in stages, i.e. I press the switch and they'll go up an inch, so I press again and up another inch -- so it takes me over 10 presses to shut each window is the same problem with all the 4 windows
any ideas please?
Jocke
Manually close the window as far as it will go and hold the window button in the closed position for 10 - 15 seconds.
Repeat the same in the direction of opening the window.
Open the windows fully and carefully spray silicone lubricant into the felt window channels. Then operate the windows fully a couple of times. Hold the window switch for ten seconds at each end of the travel... You may hear a faint click after ~10 seconds.
The windows should then freely operate with a single press.
