Powering is Stiff but not dead. ABC Suspension works fine
Old Mar 15, 2026 | 01:36 PM
silvertonesx24's Avatar
CLS55, CL63
My power steering is suddenly stiff and I can hear some noises when turning the wheel. It's not completely dead, just stiffer than it should be. However my ABC suspension works perfectly, raises up and down quickly. There are no warnings on the dash. How can I diagnose? I suspect the tandem pump, but I'm hesitant to dig into the ABC system and contaminate it or something because it works perfectly.
Old Mar 15, 2026 | 02:20 PM
Jaap's Avatar
2006 W221 S500L M273
There is usually a filter in the power steering reservoir.
I doubt in can be found separately so you may need to replace the entire reservoir.
For ABC, it may be part# A2214660102
Old Mar 15, 2026 | 02:33 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
We have to assume you checked the fluid.......
Old Mar 15, 2026 | 04:24 PM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
Check for a fluid leak in front of the front passenger tire.
