S-Class (W222) 2014-2020
Homelink
Old Jul 7, 2014 | 09:32 PM
JLamg's Avatar
2012 ML63; 2012 XKR Conv
Homelink
Wonder if anyone has advice to get the home link to work - or if you overcame any issues when you tried to set it up?
J
Old Jul 8, 2014 | 08:31 AM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
J
Did you get it to work? Or a you referring to the crappy range of it? The range is horrible due to the coating in the glass.
Old Jul 8, 2014 | 10:44 AM
AppleFan1's Avatar
2025 EQS580
I don't have any problem at all with range. It works from more than a 100 feet away.
Old Jul 8, 2014 | 10:55 AM
AppleFan1's Avatar
2025 EQS580
J
If you have a rolling type of garage door opener, it is a bit more complicated than a non-rolling one. Just closely follow the instructions in the owner's manual and your should be successful. I remember that once you perform the initial step, you need to press the reset button on your garage door opener.
Old Jul 8, 2014 | 01:04 PM
JLamg's Avatar
Thanks all - problem solved -
As I told my wife - one small step for man, one giant step for non-mechanical me!
Had to do some stuff with the garage itself because of rolling codes!
Cheers
J
