S-Class (W222) 2014-2020
Touch pad problems
Old Sep 3, 2014 | 06:16 PM
DFW_Neal's Avatar
2015 S550 ordered
Touch pad problems
Hi, anyone else with 2015 having problems with the touch pad? I can't press it and it no longer recognizes my finger. I'll take it in but thought I'd see if others have the same problem. It worked fine when I picked it up.
Old Sep 3, 2014 | 06:44 PM
ULJets's Avatar
07 S600, 09 ML63
No issues except I find it is slow to react.
Old Sep 4, 2014 | 02:37 AM
Diesel Benz's Avatar
Do you mean it does not move downwards when you press the pad from the rear? Try to lift it a bit first? Sounds like it is broken somehow and anyway needs to be changed.
Old Sep 4, 2014 | 10:23 AM
Alishami's Avatar
S500 2015
I have experienced the same problem before but I took my car to the dealership and they have updated my car software and till now it works well.
btw try to switch off you car and try the touchpad later.
Old Sep 4, 2014 | 11:09 AM
DFW_Neal's Avatar
2015 S550 ordered
Thanks for the responses. I'm at the dealer now so hopefully it will be fixed with a SW update.
Diesel_benz - that was my thought. Something mechanical is stuck or not aligned. But it is the front part that doesn't push down. The buttons on the bottom work, but then the pad doesn't recognize my finger.
Old Sep 4, 2014 | 01:48 PM
Ormond2004's Avatar
Mercedes S550
My buttons seem to work, but not the handwriting recognition.
Is there a "how to" video?
Old Sep 4, 2014 | 02:18 PM
I don't think the touchpad moves from the front at all. If you press it, do it from the centre or the rear area (will have to check this at the car, hopefully mine is not broken).
Ormond2004, what happens when you try to write letters, or numbers? Does it not respond at all or does it always fail? It shows first what you have drawn, I think it is pretty good in interpreting poorly written letters.
Old Sep 4, 2014 | 02:49 PM
Ormond2004's Avatar
Mercedes S550
Mine doesn't respond at all. I am going to sit in the car and look at the onboard manual.
One of my peeves is the lack of Command documentation. Why should I have to download a PDF or sit in my hot car to learn the functions of my new S? I think the onboard manual is lousy.
Old Sep 4, 2014 | 02:56 PM
Alishami's Avatar
S500 2015
Check out this video
http://youtu.be/JxJllH5He5o
Old Sep 4, 2014 | 03:54 PM
Ormond2004's Avatar
Mercedes S550
Thank you! I watched the video before going out to the car. Even if I go to a text box for entering an address, the touchpad doesn't seem to respond, only the three quick keys on the bottom.
Old Sep 4, 2014 | 04:04 PM
Alishami's Avatar
S500 2015
Try reseting the command system before going to the dealership
Old Sep 8, 2014 | 07:21 PM
DFW_Neal's Avatar
2015 S550 ordered
SW update at dealer today resolved the problem today.
Old Sep 9, 2014 | 04:38 AM
BenzV12's Avatar
W212 FL
Cool, good for you
Old Sep 9, 2014 | 12:09 PM
konigstiger's Avatar
'71 Pinto
Mention bulletin LI82.60-P-059737 - details here https://mbworld.org/forums/new-s-cla...ml#post6161331
Old Sep 9, 2014 | 10:43 PM
DFW_Neal's Avatar
2015 S550 ordered
Thanks for that. I also had the one listed where the tire hit the curve with park assist parallel parking. So I'll ask for that update next time I go.
