Transmission Nitpicks
1. Shifts up very quickly from 2nd under light throttle.
2. Can be harsh on downshifts coming to a stop.
3. Will "clunk" sometimes under light throttle as transmission searches and downshifts.
Just wondering if anyone else is experiencing this. Have seen no bulletins addressing throttle or transmission mapping. Overall, I'm still very happy. Thanks.
If you have KEYLESS GO do not remove the Start button.
1. Press Start button twice. This sets it to key position 2.
2. Floor gas pedal for 10 seconds.
3. Press Start/Stop once. This turns it OFF.
4. Release gas pedal and wait two minutes.
5. Then start the engine and begin driving.
Other option:
1. Turn the ignition key to the ON (not start) position.
2. Press the gas pedal to the floor and hold for 10 seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait 2 minutes for the ECU to reset. When the 2 minutes are up start the engine. Drive away and you should notice a more responsive transmission (for a while).
Thank you for sharing your transmission reset trick. I used option 1 and noticed immediate improvement. Will monitor over time. Your generous suggestion certainly confirms the value of this forum. Thanks again.
Other option:
4. Wait at least two minutes for ECU to reset. When the 2 minutes are up take your foot off the accelerator and start the engine. Drive away and you should notice a more responsive transmission for a while.
Tried it on my S63 that had 17 miles at delivery, removed the lag I had from getting on the gas under 10mph that I just assumed was part of the gripes about the AMG transmission
I found that when you switch to M and shift more (low gears, high rpm) for even a 10 mile drive, the effect appears similar. Sport mode shifts great afterwards.
Otherwise just repeat the reset as desired...
As Wolfman stated, this has been around for years.
http://www.benzworld.org/forums/w212-e-class/1965585-replacement-2014-e550-harsh-downshift-clunk-5.html
Well we'll know issue at Benz across the models
I had Mbusa buyback two brand new 2014 e55's over this and then I go my e63S
Same exact issues as the op
