S-Class (W222) 2014-2020
Check Tire pressure message
Old 07-22-2015, 11:31 PM
Donald_S's Avatar
2015 S550 4 Matic
This afternoon, while driving back from work, I noticed the "Check tire pressure" message on the display with one of the tires highlighted in yellow. However, the display shows the correct tire pressure, which is the same as in the other tires. I manually checked the tire pressure and it corresponds to that shown on the display. Not sure why it is displaying the error message.. Anyone had a similar experience? Any thoughts?
Old 07-22-2015, 11:47 PM
3sls's Avatar
1963 190SL, 1978 450SL, 2002 MINI,2004 SL500, 2004 VOLKWAGEN PHAETON,2015 S550 4MATIC
I had the same exact experience after a short overnight temperature drop. The message remained until I did a reset of the TPMS. It has not happened since!
Old 07-23-2015, 07:39 AM
Donald_S's Avatar
2015 S550 4 Matic
Interesting... It was pretty hot yesterday. I wonder if the TPMS or the sensors are sensitive to temperature extremes? I will try resetting the TPMS. Thanks for your input!
Old 07-23-2015, 09:36 AM
3sls's Avatar
Make sure you do it cold in the morning before any driving that day.
Old 07-23-2015, 04:37 PM
714Merc's Avatar
2014 S550, 2015 Cadillac Escalade ESV
Probably not, this happened to me a couple of weeks ago, no temp extremes where I live... Although my car had just left warm garage onto cool early morning air; was heading up to DTLA for meeting, it sure caused a lump in my throat when I got the warning message. I reset on the move, and have not had problem again...
Quick Reply: Check Tire pressure message
