S-Class (W222) 2014-2020
Transmission Oil TEMP workshop mode
Old Jan 14, 2016 | 11:18 PM
rellik's Avatar
mercedes
Hello, Is there any way to access the transmission oil temp from the workshop mode tool menu?
I am able to get numbers but have no way to verify which corrispond to which temperatures.
Old Jan 15, 2016 | 04:27 AM
Diesel Benz's Avatar
I have not looked a the W222 menus but do you see any sensor values (anything that keeps changing)? I would expect only part numbers and SW release codes etc.
Old Jan 15, 2016 | 01:20 PM
rellik's Avatar
mercedes
Originally Posted by Plutoe
You don't need to be in developer mode to acquire the transmission fluid temp---simply start in the control module screen and drill down!!
Thanks, the workshop mode only has engine oil temp.
I couldnt find it anywhere in the heads up or command screen.
I am not spending on a laser thermometer but I have a computer probe. The correct drain temp on the 722.9 mct is 45 deg celcius correct?
Old Jan 15, 2016 | 03:13 PM
rellik's Avatar
mercedes
You are talking about DAS Xentry diagnostic tool aren't you--because that is what I am referencing!!
Oh, dont have that. Thanks.
Old Jan 16, 2016 | 09:13 PM
evansw220's Avatar
'01 S500 AMG Sport, ABC,Distronic,Rear Side Shades // '10 E350 P2, Pano, BLK/ALM,4MATIC Sport
Since you're talking about MCT I guess you have an AMG.. The Trans Temp is shown in the AMG display mode in the cluster accessed through the steering wheel controls...
Old Jan 19, 2016 | 12:32 PM
Thanks for that clarification for the topic.
