S-Class (W222) 2014-2020
Replacement Cabin Filter...2014 S550
Old Jul 2, 2016 | 11:34 PM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
http://www.mbdirectparts.com/mercede...bin-air-filter
TWO COME IN THE BOX.....
1. UNDER GLOVE BOX PASSENGER FOOT WELL, REMOVE 3 TORX SCREWS HOLDING PLASTIC TOP OF FOOT WELL.
2. FOLD BACK REAR OF CARPET EXPOSING SPEAKER, WILL MAKE IT EASIER TO UNCLIP PLASTIC AND RE-SEAT IT AFTER FILTER SWAP.
3. SLIDE PLASTIC TOWARD YOU, 3 SLIDE HOLDERS/CLIPS KEEP THE PLASTIC UP.
4. UNPLUG 2 WRES FOR LIGHTING AND TEMP SENSOR.
5. YOU WILL SEE 2 SLIDING CLIPS HOLDING PLASTIC COVER (2)FILTERS BEHIND. REMOVE (2) TORX SCREWS, THE ONE FAR LEFT IS A BIT TIGHT TO GET TO.... SLIDE 2 CLIPS AND REMOVE COVER.
6. YOU WILL NOW SEE THE (2) FILTERS. (NOTE POSITION OF FILTERS) TAKE ONE FILTER OUT AT A TIME. YOU WILL NOTICE THE FILTER HAS 2 HOLES ON ONE SIDE (THIS IS THE TOP OF THE FILTER) THERE ARE 2 PLASTIC PINS AT THE TOP OF THE AIR BOX THAT THE FILTER SEATS INTO.
*** YOU MAY NEED TO LOOK UP TO CONFIRM YOU SEATED THE FILTER ON THE 2 PINS CORRECTLY.
7. NOW DO THE SECOND ONE.
D O N E
REVERSE THE ABOVE STEPS AND ENJOY THE FRESH AIR AND INCREASED VOLUME OF AIR. IF YOU HAVE THE PERFUME DISPENSER, YOU MAY NOW NOTICE IT MORE IF YOU HAVE IT TURNED ON.
Old Jul 4, 2016 | 02:34 PM
Nice Ride's Avatar
D O N E
Fixed Link
