S-Class (W222) 2014-2020
Cold Tire Pressure
Old Jul 21, 2016 | 08:34 PM
RJC's Avatar
RJC
Various
Cold Tire Pressure
For those with the 20" AMG wheels, what cold PSI are you running in your tires? I was surprised to see the placard in the door jamb indicates 39PSI cold. Although I have a coupe I'd imagine the recommended PSI should be the same as the sedan.
TIA
Old Jul 21, 2016 | 11:59 PM
docsout's Avatar
2023 S Class 2013 SL
33psi per fuel cover.
Old Jul 22, 2016 | 01:50 AM
RJC's Avatar
RJC
Various
33psi cold sounds right, 39 did not.
thnx
Old Jul 22, 2016 | 10:45 PM
RJC's Avatar
RJC
Various
More info
Coupe's cold pressures 32 all the way around...39 is for max load.
Old Jul 22, 2016 | 11:55 PM
PeterUbers's Avatar
Use the info on the fuel door for more accurate info
Old Jul 23, 2016 | 06:13 AM
jenz's Avatar
S, GL
Play around with it, used to run 34 cold which felt fine
After a balance, tire shop put all at 39 cold which felt even better, only then did I realize it felt slightly sluggish at 34 like driving thru sand
Old Jul 23, 2016 | 04:57 PM
Mitch Alsup's Avatar
Top Answer: 1
S600
I am runing 39 PSI and the car has plenty of grip.
Mine is a 600 and I am averaging 22 MPG at 39 PSI.
I know it seems high, but the tires work--now If I can only wear these out and put on non-run-craps.
Old Jul 23, 2016 | 05:24 PM
pvrick's Avatar
s550 e 320
I am running 38 front and 41 rear. Replaced run flats w continental d w s 06.I drive twisty roads and the extra pressure helps avoid edge wear. S 550
Old Jul 23, 2016 | 06:41 PM
docsout's Avatar
With the short side walls and stiffness of run flats, for comfort sake would it be better to run 32-33psi?
Old Jul 24, 2016 | 12:13 AM
RJC's Avatar
RJC
Various
My coupe's recommendation is 32 cold and it rides nicely.
