Getting Parktronic to work
Any experience and comments are appreciated.
- Set the side mirror to a reversing position that gives you a very clear view of the rear tyre - When you park the car with parktronic make sure that you press that side mirror adjustment button before starting to park so that the mirror moves to the reverse position(showing you the rear tyre). When you get close to the curb with the tyre use the brakes to slow the car down till you are almost on the curb and then brake to a stop and change gear into drive even if not prompted to do this. The car will continue with the auto parking if it is already in a suitable position, which it usually is at this point. (I discovered this by accident when I wanted to abort the parking and it just continued as if nothing happened)
- Alternatively make sure that you park behind a vehicle that is not very narrow or not parked very close to the curb - As I understand it Parktronic cannot "see" the parking but rather positions the vehicle relative to other vehicles. This unfortunately means that if you park behind a significantly narrower car or one that it is very close to the curb it will probably try to mount the curb.
Hope this helps
Hope this helps
Its a bit sad they use the term "nothing but the best" with them falling short often....
No one and nothing is perfect, I get it but its a bit of a stretch. MBRACE is a disaster compared to OnStar...
Re. mbrace, it depends on what you mean. Internet, roadside assistance, the apps, concierge services, remote locking or start, or?
Some things are decent, some horrible. Overall a useless service (just like on-star IMO). I only use it for emergency services with gps location in case of an accident. That worth it to me. The rest is done via iPhone/Bluetooth.
I have to admit that Mbrace is much improved in the SL with LTE Internet speeds. Still wouldn't use it...
CarPlay with Siri is great for everything else
