S-Class (W222) 2014-2020
2015 s550 aux battery location
Old Dec 26, 2017 | 10:55 PM
jmuld007's Avatar
2015 s550 4matic
where is aux battery located 2015 s550
Old Dec 27, 2017 | 10:16 AM
konigstiger's Avatar
'71 Pinto
Check trunk, current OEM part # 0009829308.
File Type: pdf
File Type: pdf
Old Dec 27, 2017 | 12:50 PM
jmuld007's Avatar
2015 s550 4matic
Thanks will check it out
Old Jun 28, 2018 | 03:15 PM
Chrisgmt's Avatar
2015 S550 & 2012 E550 Convertible
Location for the Aux Battery in 2015 S550 W222
Were you able to find the battery? Is it actually in the trunk? I have read several posts stating several different locations...so with this, I am confused and don't feel like taking apart the car only to find it is not in that location. Please help :-)
Old Jun 29, 2018 | 04:58 AM
Diesel Benz's Avatar
Are you talking about the same car? You have a different car in your profile, that is why I'm asking.
There are different W222 models too, if you don't want to remove the trunk panels, post your VIN and we can double check. I did not read the pdf from konigstiger but it probably states which models it is valid for. Only some hybrids likely have a different configuration.
Old Aug 3, 2018 | 05:36 PM
Chrisgmt's Avatar
I also have ab e550 conv. This s550 is one I just bought. I did find the aux battery in the trunk passenger side. I had to remove almost all of the interior of the trunk. It was pretty easy. Thanks for responding. I need to turn on my notifications, I did not see that I had a response.
Old Aug 23, 2018 | 10:51 AM
Hoover2112's Avatar
2014 W222 S Class SE 350d
Just to confirm..
Given the horrendous quote i just had to supply and fit a replacement I just wanted to check on this before i buy one and fit myself.
Its the rear panel in the boot/trunk on the right hand side - remove the cover (had a look - looks like the picture) remove the panel with the 3 screws and swap out the battery behind it.
Mines a W222 2014 350d but assume its the same.
From what i read seems fairly simple and if I can save £160 for 10 minutes with a screwdriver than I'll give it a go!
