Driver side low beam TOO low
2014 S550 4MATIC
On my 2014 S550 the driver side low beam is pointed too towards the ground, the right one is higher but could also be raised a bit. I know on my W221 S63 there were adjustment screws for the low beams and then when turning the car on the auto leveler did its thing and went to the position I set and all was well. I found the same plastic screws above the low beams on the 2014, I assume it's the same procedure?
Any info would be greatly appreciated
merc.man (09-25-2018)
