I want to lower my car, anyone has experience with Amazon OBD-2 module?
obd-2 Lowering module Amazon
I use a similar module and really like. But if you ride that low, you will stress the struts and they can blow out when hitting a pothole as the air pressure is higher with less travel in the air chamber.
I don't don't know this module modifies the ride height. Previous ELM's or links spoofed the system it is at stock height. I don't know if this one simply modifies the values. If so, it would be recorded/logged.
That said, it's a question of taste. I think -32mm F/R would look great on your car
zk2004mb (06-17-2024)
Nice Ride (04-26-2020)
Super Moderator
Received 3,239 Likes
#32
I have contacted a couple of vendors even the seller of this amazon module and so far everyone has said only 4matic. I havent check renntech because they charge too much mercedes tax. If anyone with MBC using lowering modules please send me a recommendation. Thanks
#34
I have one and it works amazing. If you need to raise it back up for any reason you just plug it in and pop her back up. It takes a second to figure out the interface using the comand wheel...but once you figure it out its easy. There are a couple of preset heights you can choose from, or go custom to your tastes...mine is custom (not sure of the exact settings)
If you have any questions feel free to PM me!
#41
What is the size of wheels installed here? What module setting did you choose?
Does lowering like yours have a strong effect on driving comfort?
#44
I have a LoMo 2 for sale if anyone is interested. You can change the height by using the steering wheel control buttons. You don’t have to plug anything in each time. It also can be transferred to other cars - it is not locked to the vehicle’s VIN like the OBD solutions. I have it posted in the marketplace section.
#45
#47
any thing negative? just plugs into the obd port and adjustments are made from the steering wheel? only reason i would consider this unit is so i can resale when i sale the car since i know i wont be keeping it for more than a year....
#49
https://www.amazon.com/dp/B083F87VYT/
⚠️ Multibeam LED Activator
For US/CA Mercedes Benz cars with limited headlamps operation!
After activation full led 640 headlamps will work exactly as EU/US SA642+628
550$ with shipping
550$ with shipping
#50
I don't think you can resale it. Ask them before you but it. Load the program the OBD and do all the setting though your steering wheel button.
