Auxiliary Battery Malfunction
My 2015 has been through three auxilliary batteries in 55k miles. First you get some battery malfunction warnings on the dash, then a few days later your distronic and a few other doo dads start to fail, and THEN you car goes into limp home mode, and THEN it gets towed to the dealer after it stops by the side of the road. So moral of the story is to get the battery replaced within a week or two of first seeing the warning on the dash. Ask me how I know......
Nice Ride (01-02-2020)
![](https://cimg3.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_20190727_074958_c169244bed845996b3016a44d44787ad777e01fd.jpg)
Remove the flip up floor panel 2 T20 screws
remove the rear trim panel. Two push/pull clips, then pry up to lift the panel straight up
Play safe and disconnect the neg battery term from the main battery.
View of the goal. The Aux battery is in a black plastic case that has a snap on lid. You don't remove the case, just pop off the lid
10mm nut x 2 that hold down the fuse box. You need to just move this a little to the side to gain full access
Flip up the Aux Battery cover, then unbolt the neg then pos terminal. The battery will lift out
So I did this aux battery change out on my 2014 S550. Some tips:
1. Remove 3 nuts holding the fuse box (not just the 2 as mentioned above). The 3rd nut releases the battery box so it easily slides out. The battery is super heavy to remove otherwise
2. The 12v clip can be removed by reaching down once the right panel is loose.
3. Remove all the panels in order to more easily remove the right side panel. This includes removing the chrome trunk sill. Remove 2 clips and then pull it up....it’s tight, feels like you will break it....but it doesn’t break...it releases additional tension clips underneath.
Additional Photos / Notes...
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/640x480/img_0633_d9b1422619c338d12a9f28d79cc36371b2f10bca.jpg)
Additional look when you pull cover away. 2 Push clips on top under rear window need to be removed.
![](https://cimg5.ibsrv.net/gimg/www.mbworld.org-vbulletin/640x480/img_0634_db392046c2ca6a57074f3c68b513796d74d9e5d0.jpg)
I had to remove this additional nut to move the module out of the way.
![](https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/640x480/img_0635_dd1fcd6424e206b841797f5ccbf2920dd1c715b9.jpg)
This black clip under the battery case can be pushed down to allow the battery case to slide out. ( You will need to remove nuts around the fuse panel to move it out of the way.
![](https://cimg7.ibsrv.net/gimg/www.mbworld.org-vbulletin/640x480/img_0636_7251423fc47ab72c6e8ac1013ee3875f0bdb9aa9.jpg)
Old Battery Voltage reading after removed
![](https://cimg8.ibsrv.net/gimg/www.mbworld.org-vbulletin/640x480/img_0637_9d2f7819ec8d99092790e68dd067c19455d06a64.jpg)
Old Battery Amp reading
![](https://cimg9.ibsrv.net/gimg/www.mbworld.org-vbulletin/640x480/img_0638_bd75b9f83a8805abba9a87a452175112d45999cb.jpg)
2nd test to confirm
![](https://cimg0.ibsrv.net/gimg/www.mbworld.org-vbulletin/640x480/img_0639_91b89e015334291a1510155181bad10f4aba8c0a.jpg)
2nd test to confirm
![](https://cimg1.ibsrv.net/gimg/www.mbworld.org-vbulletin/640x480/img_0640_71fab36cb2382394db0deba0be6fa76dc68777ba.jpg)
Notice Sell By Date TOP Right of sticker.
ECO turned Green immediately, Distronic worked immediately. ( Both showed error every time car was started.) Adaptive Headlight error will not clear...All else OK. Start stop worked immediately, no long drive needed to charge.
Anyone have an idea about the adaptive headlight error?
12.18 V is essentially dead. Anything below 12.4 on a charged battery means it needs replacement. The low amp-hours confirm it, of course, but the electronics are affected by the low voltage. It's just that because the battery can't put out the current, the voltage drops when the electronics try to draw some.
I have a 2014 E350 with same error message. Dealer replaced it once under warranty but would not honor warranty on replacement battery. After getting quote from dealer, I purchased a battery from Autozone with same specs. It worked fine for while, then intermittently, then error message returned and stayed on. Autozone checked battery and it's still good. Dealer now says I have to have OEM battery and wants $475 (really!!??) to replace with OEM. That price sounds outrageous! I'm deferring that expense for now as they're charging $675 for B service and additional $650 for transmission service. I see auxiliary batteries with MB logo advertised for $129 (https://www.fcpeuro.com/products/mer...BoC_RMQAvD_BwE) and something advertised as "genuine" MB but without logo on Amazon for $49 (
https://www.amazon.com/Genuine-000000004039-Mercedes-000000-Battery/dp/B007XRBCAK/ref=asc_df_B007XRBCAK/?tag=hyprod-20&linkCode=df0&hvadid=312430092407&hvpos=1o3&hvnetw=g&hvrand=11154813042051173775&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9012589&hvtargid=aud-801657747996:pla-571313375036&psc=1
) Replacing the battery is very simple, so I plan to buy one myself. Has anyone else had experience with "genuine" MB batteries from non-dealers? Thanks.
![https://www.amazon.com/Genuine-000000004039-Mercedes-000000-Battery/dp/B007XRBCAK/ref=asc_df_B007XRBCAK/?tag=hyprod-20&linkCode=df0&hvadid=312430092407&hvpos=1o3&hvnetw=g&hvrand=11154813042051173775&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9012589&hvtargid=aud-801657747996:pla-571313375036&psc=1](https://mbworld.org/forums/images/misc/amazon_icon.gif)
#32
I have a 2014 E350 with same error message. Dealer replaced it once under warranty but would not honor warranty on replacement battery. After getting quote from dealer, I purchased a battery from Autozone with same specs. It worked fine for while, then intermittently, then error message returned and stayed on. Autozone checked battery and it's still good. Dealer now says I have to have OEM battery and wants $475 (really!!??) to replace with OEM. That price sounds outrageous! I'm deferring that expense for now as they're charging $675 for B service and additional $650 for transmission service. I see auxiliary batteries with MB logo advertised for $129 (https://www.fcpeuro.com/products/mer...BoC_RMQAvD_BwE) and something advertised as "genuine" MB but without logo on Amazon for $49 (https://www.amazon.com/Genuine-00000...13375036&psc=1) Replacing the battery is very simple, so I plan to buy one myself. Has anyone else had experience with "genuine" MB batteries from non-dealers? Thanks.
https://www.eeuroparts.com/Parts/861...BC-0009829308/
The OEM battery is AGM. A cheaper flooded cell battery, even if it physically fits, will operate at a lower voltage and cause problems. Always go by the MB part number, A 000 982 93 08.
#33
Neither of those batteries looks like the OEM battery, which is this:
#35
Drat! My 2018 S560 just had the same failure and less than 15 months old. Made an appt for repair - anyone know approx how long the dealers take with this?
#36
I just had my aux battery replaced and the service rep expressed surprise that it failed so early (14 mos and 6k miles). What really surprised me was when he said that the aux battery fails are not covered under extended warranty protection, only under the normal 48mos/50k. I have the 7 yr extended warranty and found this to be annoying, especially given the number of failures being reported. I don't know if he is right or not, though.
#38
#39
#40
AGM batteries operate at a slightly higher voltage when charged than flooded cell. A standard battery is considered fully charged at 12.7 V. An AGM will be more like 12.9. It's just a characteristic of the AGM cell. It's one way that sensitive battery monitors can be thrown off by the wrong battery type and is one reason the aux. battery has a "Replace only with same technology" warning label.
Nice Ride (09-07-2019)
#41
The Aux battery in my 2015 S65 triggered the failure warning 2 weeks ago. I had it replaced, the original lasted just over 5 years. That is consistent with the life of the AGM Consumers batteries in the SL's.
In my opinion the SL has a much better battery management system since all the consumer loads begin working as soon as the AGM battery reaches 50% charge while the car is running. That usually takes no more then 10 minutes even with a weak battery that will not hold a charge after shut off. The S does not work this way.
#42
I picked up my 2018 S450 4Matic from MB of Owings Mills, MD, last Saturday. As soon as I got on the highway, got the message 'Auxiliary Battery Malfunction'.
No Distronic Cruise control/stop start functionality for a 300+ mile drive. Not sure what other functions are covered by auxiliary battery? Possible Hold brake function?
Called MB roadside assistance , who confirmed that auxiliary battery always needs to be replaced when this message appears.
Local MB dealer in Hartford replaced it for free as it is under warranty.
Bad experience after purchasing the CPO car, that this happened immediately.
#43
I picked my 2018 S450 4Matic from MB of Owings Mills, MD, last Saturday. As soon as I got on the highway, got the message 'Auxiliary Battery Malfunction'.
No Cruise control/stop start functionality for a 300+ mile drive. Not sure what other functions are covered by auxiliary battery? Possible Hold brake function?
Called MB roadside assistance , who confirmed that auxiliary batter always needs to be replaced when this message appears.
Bad experience that after purchasing the CPO car immediately this happened.
Supercaps are an important new technology and will be in all cars in the near future. MB was unusually innovative in exploiting their capabilities fairly early, and we are seeing the price of early technology adoption. As annoying as it is, I'm glad that Mercedes engineering isn't the conservative organization it once was, when its customers watched BMW and others bringing all the new technology to market a few years before MB.
#44
Battery model Number?
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_20190727_075905_bca126e7d3ac2bbb6bb2239ca70a60383c456034.jpg)
![](https://cimg7.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_20190727_080053_2bd5231eb053f3a07b6946fa08f4f174423d096e.jpg)
![](https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_20190727_075938_542cd6728694150a9ceccfa301386df12260cc91.jpg)
![](https://cimg7.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_20190727_080116_5d8663572f3d5e2f5c86d726534e2ca65db545c7.jpg)
![](https://cimg9.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_20190727_080305_f816122450d4d9d773226732252a5bd477247fbc.jpg)
#45
#46
Found this.... Purchase once from FCP, Free Shipping and Free Replacement for Life....
https://www.fcpeuro.com/products/mer...mer-0009829308
#48
Just ran Xentry on my 2016. It shows that the Aux Battery has high internal impedance. >1000 mohm. With that impedance it is on the verge of failing. Still is working fine no other problems. From what I can see this is a standard motor cycle battery which are readily available for about $50. Still have some warranty left. Will try to persuade the dealer to replace the Battery.
#49
Battery Tender Auxiliary Battery?
I have 3 cars. I don't drive any of them often. I have used a separate on each car for the past 3 years to charge the main battery. They have worked flawlessly. One car is only driven twice a year and the CTEK always keeps it ready to go.
I decided to purchase a 4th CTEK 40-206 and install in on my 2018 MB S560 Auxillary battery. Took the CTEK to my MB dealer, and they refused to install it on the S560. I explained that Mercedes sells their own MB branded model of the same CTEK 40-206, the answer was still no. I asked to speak to the service manager and he told me "we install trickle chargers all the time, but ONLY ON THE MAIN BATTERY". I tried explaining MBWorld forums are filled with owners who have 2 chargers hooked up to their Main and Auxillary batteries but the Service Manager insisted the CTEK would "mess with the electronics" and void the new car MB warranty.
I asked the SM how the CTEK might "mess with the electronics". The SM said the CTEK was made for full-size batteries only and might overcharge the Auxillary. I tried showing the SM the motorcycle symbol (indicating a reduced charge for a smaller battery) but he blew me off. The SM then told me the CTEK would continue to overcharge the auxiliary because it "would not recognize when the battery was fully charged." I tried explaining there is circuitry in the CTEK to stop the charging once a full charge is achieved and then it regularly checks the battery, as long as it is connected and adds charge whenever needed. Again the response, "it would void the warranty".
It was apparent, the SM was not going to budge. In total frustration, I called another local MB dealer and spoke to a service advisor. I received essentially the exact same answer. Have I misunderstood the postings on MBWorld? If using a CTEK on the auxiliary battery will indeed destroy my electronics and void my warranty, I should call the SM and thank him profusely for his warning. But if a second CTEK can successfully be installed on my 2018 S560, I'll simply take it to an independent shop. I would like to do the same install on my 2017 SL550.
I realize this installation would be extremely simple - just attach a quick connect to the positive and negative battery terminal and plug it into the CTEK. I would do it myself (as I did all three of the main batteries on my other cars) but the auxiliary location on my S560 requires the removal of more parts than I am comfortable doing.
Would appreciate any of you confirming the successful install of two trickle charges on your own main and auxiliary batteries.
#50
When I had my 2015 S550 I experienced the auxiliary battery failure at the start of my drive from southern Florida to RI. Made the trip fine but distronic did not work for most of the trip. That was annoying but you can still drive the car. It was fixed under warranty. Read somewhere that if you do not operate car for over a week Mercedes recommends putting on trickle charge. I do that now with my 2018 560 and 2016 GLE 400 and haven’t had a battery problem since.
