S-Class (W222) 2014-2020
Washer fluid not coming out
Old Aug 13, 2019 | 03:20 PM
MerS550's Avatar
S550 2016/ E-Class 2017
Gents,
I have an issue with my S550 2016 which is when I operate the windshield wipers they are respond perfectly but the washer fluid not coming out while I can hear the pump working!
Does anybody experience anything like this? the reservoir is full.
I need the connection diagram from reservoir till the wiper blade if anyone have it!
VIN# WDDUG8CB1GA244887
Old Aug 13, 2019 | 03:50 PM
konigstiger's Avatar
'71 Pinto
Should be covered under MBUSA 4-year/50,000 mile factory warranty.
File Type: pdf
Old Aug 13, 2019 | 04:06 PM
MerS550's Avatar
out of warranty
Old Aug 13, 2019 | 06:50 PM
'71 Pinto
I understand magic vision wipers are fine. You need to check reservoir fluid although full if you use other than MB fluid some aftermarket products (i.e.: rain-x) can cause pumps (20 & 30 in diagram) or hose line (250) to clog. Check hose nozzles (connection points) at reservoir. Here is an underside view of hose assembly.
