Catalytic converter for 2015 S550 4Matic
I am certainly glad I decided to purchase the MB extended warranty for $3,450. I was having an issue with intermittent check engine light and took it to the dealer and they said I needed a new catalytic converter. They ordered one from Germany and tell me the part alone is over $3,000. The car was running fine it would just be an intermittent yellow check engine light that was coming on and off They said the diagnostics required a new catalytic converter.
Has anyone else had these issues with the catalytic converter ? I’m not sure other than poor emissions if I would notice any issues.
MBNUT1 (10-23-2019)
It didnt take mine very long. If I remember correctly it was at the dealer for less than a week, but they also didnt tell me that it would have to come from Deutschland.
FWIW, "emission control systems come with a different warranty (Federal) than the normal new MB 4 year/50k mile coverage. In certain situations it can last up to 8 years.
Too many german broads
Not good, should not be failing so soon. Most third party warranties (even the best) exclude exhaust components and catalytic converters. I saw Mercedes has a 8 year federal emissions, does this include the catalytic converter?
I am not clear if it was covered by CPO or the emissions warranty, the dealer just advised that it was covered.
I have the same exact issue. Mercedes told me it is not covered by extended warranty and my 2016 S550 is CPO. I'm glad I didn't wast any money buying 2 to 3 years extended warranty. I will replace it out of pocket but I can get it a lot cheaper for 1.5K rather than 3K
Received 4,435 Likes
'71 Pinto
'71 Pinto
To clarify only items with Asterix are covered 8/80,000.
b) what kind of gas do you put in it?
c) how many miles per gallon were you getting?
d) does the car eat any oil between changes?
cjaredscott (10-21-2020)
2004 W240 Maybach 57
Check Engine Lights (CEL) occur for several reasons. A code needs to be reported to be sure you are comparing apples to apples. Many CEL conditions will not affect performance/mileage, and possibly not even emissions. Which is the reason they exist in the first place.
You can get a CAT for pretty cheap if you shop dealers/look online. Most shops can replace the CAT its not a difficult job. Some people would take this opportunity to run catless downpipes and go with a aftermarket solution.
Most aftermarket GOOD extended warranties do not cover the cats either. I have had warranties from Fidelity, CNA, Ally, Lexus with their "platinum bumper to bumper coverages" and each one excluded the catalytic convertor as a covered component.
Knock on wood, I've never had to replace a cat on one of my cars, not even the one I drove to 176k miles. Here's a page that describes how they can go bad ... https://www.walkerexhaust.com/suppor...ter-fails.html
MED177-N3/10 Motor electronics "MED177" for combustion engine "M278" (ME)
P042000 - The efficiency of the catalytic converter (cylinder bank 1) is insufficient
technican said there was a problem with the Right side Catalystic Converter efficiency "caused by metals in catalytic converter depleting, allowing it to not clear exhaust fumes."
Is this something I need to worry about? or are they just trying to fleece me? Seems kind of wrong to need to replace a catalytic converter when my car only has 22,000 miles (2015 model purchased in 2014 - so just outside the 8 year warranty on exhaust) Thanks in advance for any advice.
'71 Pinto
As posted previously in this thread, discuss this with MB dealer CC is covered under warranty for 8 years / 80,000 miles whichever comes first, see attachment. Out of warranty, make a deal with Scrappy Larry... ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
