S-Class (W222) 2014-2020
P0050 Code
Old Nov 5, 2019 | 11:01 AM
604benz's Avatar
2015 S550V
P0050 Code
Hi Guys
The yellow check engine light came on yesterday, it seems to be driving normal, lots of power and smooth
I hooked it to my scanner this morning and got P0050 code, Bank 2 Sensor 1, anyone else had this issue,,is it a DIY fix, does anyone know where the sensor is located, any info appreciated
Old Nov 6, 2019 | 02:37 PM
hyperion667's Avatar
2012 CLS63
I'm guessing o2 sensor, they can be tough to get to.
Old Nov 6, 2019 | 07:01 PM
604benz's Avatar
2015 S550V
Yeah I believe they have four 02 sensors on the S550s, I just got to figure which is side is bank 2 sensor 1 location
I cleared the code and engine light is off for now, if it comes on again ill pick one up and get my indy shop to install as I don't have a lift to get under the car.
Old Nov 7, 2019 | 08:30 AM
konigstiger's Avatar
'71 Pinto
See if this helps.
Old Nov 7, 2019 | 02:26 PM
604benz's Avatar
2015 S550V
Thanks Konigstiger
I was reading online to check for a blown fuse before purchasing the O2 sensor on some vehicles, any idea if this relates to the W222, if so any idea where fuse woud be located
Old Nov 7, 2019 | 03:34 PM
'71 Pinto
Not aware of any fuses. Short of replacement check/clean connections.
