S-Class (W222) 2014-2020
Heated Windshield Function
Old Nov 27, 2019 | 07:30 AM
SteveVukelich's Avatar
2020 S560
I have a S560 with option 597, Heated Windshield. I took a rock chip and crack to the windshield. Does anyone know how the electrically heated windshield works and whether this accident will affect the function operation? Can it be filled or does the entire windshield need to be replaced?
Old Nov 27, 2019 | 05:05 PM
AppleFan1's Avatar
2025 EQS580
If it's cracked I'm pretty sure you need to replace it. I already had to replace 2 windshields (not the heated type). The first one was replaced in May and the second around August even though it was cracked in June (about 4 weeks apart). Flying rocks are a huge problem especially in construction areas.
Old Nov 27, 2019 | 08:20 PM
OnlyGerman's Avatar
Too many german broads
When my heated one got cracked I made sure it was replaced OEM by the dealer. Safelite said they had a "heated" windshield, but I doubt it. And I wouldn't let them do it to begin with lol
Old Nov 30, 2019 | 03:57 PM
2020 S560
I have a call into MB on this. I took a photo in the non-sun blocked area and you do see fine horizontal traces. See photo.
Old Nov 30, 2019 | 04:30 PM
OnlyGerman's Avatar
That is normal...
Old Dec 2, 2019 | 04:57 PM
2020 S560
Mercedes Benz just confirmed that an electrically heated windshield showing rock chip damage, which includes a crack, is not repairable and must be replaced. And after replacement the sensors/cameras must be re-calibrated for the subsystems to function correctly.
Old Dec 6, 2019 | 09:04 PM
2020 S560
I finally had the windshield replaced and all of the sensors re-calibrated. The windshield was $2800. I was told it was that expensive because of the heating element embedded into the glass. The heating is performed by a transparent film in one of the glass layers and not with wires as I had thought. Fortunately it was covered by my Comprehensive policy and I had zero deductible. Final price for the repair was $3850.
Old Dec 7, 2019 | 09:22 AM
1bad540's Avatar
s550 Diamond white amg pano
wow.
Old Dec 7, 2019 | 12:05 PM
chassis's Avatar
2017 GLE350 4MATIC
Congratulations on a successful repair. Cost is not a surprise.
My wife's new BMW had a cracked windshield replaced by the dealer, using OEM glass. Cost was about 1/3 of the amount posted above. Add for larger size S-Class, add for heated feature, and add for M-B factor, and the cost is easily arrived at.
Glass is thinner in vehicles in the modern era, for weight and cost savings to the manufacturers. As a result, cracks are more common than in the past, notwithstanding stronger glass material.
