My 360 cameras stopped working just the other day, I had just washed the car so I suspect the rear camera got wet.
I decided to have a go and remove the trunk lid trim panel to take a look, however Im unable to remove the Hazard triangle bracket.
WIS doesn't give much detail just says to unclip it. Looks like it should slide to right or left and lift off the the white clips. Photos attached. It slides a little in either direction but not enough to remove it. I've tried using a little more force with a rubber mallet and a small piece of timber but it still wont come off the clips.
Anyone out there done this before? Any help much appreciated.
From photo, looks like you slide to the left, then lift left side off, then slide all the way to the right and lift off...
