Brake pulsation/vibration issue between 40-50mph
I recently replaced front and rear brakes and rotors and about a month later I experienced pulsation during braking at the above mentioned speed. The brakes were installed by an independent mechanic, but I purchased the OEM brakes myself. However, I took the car to an authorized dealer who said that the rear rotors were warped. As they were under warranty, I had the rear brakes and rotors replaced, but the problem is still there. I did not have this issue before the new brakes and rotors were installed. Also, I drive my cars very carefully, so I’m certain it’s not a personal driving issue. I’m curious if someone else who had the same issue was able to resolve it successfully.
Thanks,
Jack
Thanks,
Jack
2010 E350 4Matic
I have seen similar issue posted before. They solved the problem by replacing the rotors again.
https://mbworld.org/forums/e-class-w...ml#post8121323
Hiker_Jack (09-09-2020)
To help with getting the most out of brake rotors, wheels should be torqued and don't drive through rain puddles.
2010 E350 4Matic
[QUOTE=Jud Chapin;8152143]To help with getting the most out of brake rotors, wheels should be torqued and don't drive through rain puddles.[/QUOTE]
It should not be the drivers responsibility to dodge rain puddles for the sake of rotor warping prevention.
