S-Class (W222) 2014-2020
2015 S550 power steering whine/is ABC fluid low?
Old Sep 28, 2020 | 02:13 PM
Meccadon123's Avatar
2005 Range Rover
I have a whine when turning the steering wheel. Don't see a "power steering reservoir". Does the power steering use the ABC fluid? I do see that reservoir. Is the system combined? Should I check the ABC fluid? Are the 2 even related? under 39k on the clock. Any help will be appreciated. Thank you
Old Sep 28, 2020 | 02:20 PM
Katie22's Avatar
18 AMG GTC and 22 F150 Limited. Past owner 16 Maybach, 17 Brabus Smartcar, 06 Ford E150, and 22 G70
Yes power steering is ran off of the ABC pump. My pump had to be replaced and it started with the same issue you have. A while that got worse with time.
Old Sep 28, 2020 | 03:35 PM
2005 Range Rover
Thank you..Think i'll start by adding fluid and see where that gets me.
Old Sep 28, 2020 | 06:07 PM
2005 Range Rover
MOds please delete this. Found a thread with my issue.
Old Sep 29, 2020 | 04:40 PM
MBNUT1's Avatar
2010 E350 4Matic
Could be wrong but as the thread starter I think that you can delete the thread yourself.
Old Sep 29, 2020 | 05:32 PM
2005 Range Rover
I tried believe me.. can't seem to locate "delete".. found "edit".. but nothing else.. I'm sure they'll come along and clean up at some point.
Old Sep 30, 2020 | 03:22 PM
MBNUT1's Avatar
2010 E350 4Matic
I agree. I just tested it in the test section. I would have sworn we used to have that ability but I agree it's not there anymore.
