S-Class (W222) 2014-2020
Spacer compatibility
Old Feb 15, 2021 | 09:09 AM
dweb4's Avatar
S550 4-matic
I just traded my W221 4-matic for a 2014 4-matic. I had a set of H&R 20mm rear and 15mm front spacers on it. Would anyone know if this setup is compatible with W222. My car now has staggered fit and wasn’t sure I would like to mount them to give little more aggressive stance. Thanks
Old Feb 15, 2021 | 09:32 AM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
Offset is the same. 20MM may introduce some rub though.
Old Feb 15, 2021 | 04:58 PM
Sumfuncomet's Avatar
2020 S560 sedan, 2018 Volvo v90 Cross Country
try them on, it might look goofy though if spaced too far. will you need to get longer lug bolts? spacers that thick DO put increased strain on wheel bearings. I really think its best to get the wheel with a correct offset.....I know, more money though.....
Old Feb 16, 2021 | 09:25 AM
dweb4's Avatar
S550 4-matic
Thanks, I'll try them on and see how it looks if it's off in appearance I'll sale the spacers. Yes I have all the longer H&R lug bolts to match. I ran the spacers for almost 5 years on my W221 and didn't experience and hub, bearing or suspension issues. But will keep the thought in mind.
Old Feb 21, 2021 | 06:27 PM
dweb4's Avatar
S550 4-matic
Got the spacers on fit is similar to my W221 tires now flush with the fender. Rides still the same has little more aggressive stance. Here’s couple shots before it got too dark.
