S-Class (W222) 2014-2020
KEY fob
Old Feb 20, 2021 | 12:32 PM
Denis Osullivan's Avatar
2018 s560v4
KEY fob
Just bought a 2018 s560 with two key fobs. Both work via pressing the buttons, but only one will open the door via touching the door handle. I replaced the battery but still not working like the other remote.
Thanks for your help.
Old Feb 20, 2021 | 04:30 PM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
I think there is a way to turn off RF on the remote. There is a button sequence you need to hit.
Old Feb 20, 2021 | 04:58 PM
2018 s560v4
I wish I knew the sequence. Lol
Old Feb 20, 2021 | 05:53 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
I had this exact case with my previous car, and after a second battery replacement the fob worked again. Apparently, some batteries are just duds ...
Old Feb 20, 2021 | 06:16 PM
2018 s560v4
The FOB works just can’t open door touchless
Old Feb 20, 2021 | 06:28 PM
That's what happened to mine as well ... buttons on fob worked, but keyless-go functions did not until I tried another battery ...
Old Feb 20, 2021 | 09:48 PM
2018 s560v4
Fixed
I took the FOB into the car and the car it didn’t recognize it when I tried to start it. It then told me to put the key into the center console slot. The car recognized it quickly and was able to start the car. Shut off the car and from the outside closed the door and touched the handle. It now works.
Prior to this, when the FOB didn’t work with the Keyless Go on the handle I just switch FOBs and never tried to further use the deactivated FOB
Old Feb 21, 2021 | 03:07 AM
sclass350d's Avatar
W222 Sclass
Double press the lock button on the key fob. This is used to enable and disable the key from sending the rf signal.
I always disable the rf transmission in my spare key I'm not using as it will drain the battery eventually. So I only enable it on the key I use.
Old Mar 10, 2021 | 08:12 AM
Jsmuve7's Avatar
2018 S450 4matic
On a related note... Is there a way to match the key fob to a user? For example, when driver 1 button is selected in the car the seat, steering wheel etc adjust for driver 1, driver 2 button selected...adjusts for driver 2. Can this function be paired with the key fobs? If car is unlocked with key fob 1, seats, etc adjust for driver 1, unlock with key fob 2, presets adjust for driver 2. I don't see this anywhere.
Old Mar 10, 2021 | 09:27 AM
konigstiger's Avatar
'71 Pinto
No, memory buttons only.
Old Mar 10, 2021 | 11:38 AM
Jsmuve7's Avatar
2018 S450 4matic
Thanks... just thought that I might have missed it someplace.
