S-Class (W222) 2014-2020
Rocker Panel Loose in Front
Old Mar 11, 2021 | 07:40 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Sometime in my car's past the forward edge of the rocker panel came loose. I've tried pushing it back in, hoping it would snap into place, but no luck with that approach. My next plan is to take off a wheel and then remove the fender liner in order to see up in there and try to tell what's let go.
Just thought I'd post here in case anyone's ever taken one of these off and can give a suggestion of how to figure out the problem.
Old Mar 12, 2021 | 09:10 AM
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
Old Mar 12, 2021 | 10:38 AM
DaveW68's Avatar
Veteran: Army
2015 S550
Mine are exactly the same as yours....on both sides.
Old Mar 12, 2021 | 11:37 AM
schack's Avatar
2014 S550
Had the same problem but on the driver's side only. I tried to push it back in and it wouldn't stay. I mentioned it to my MB Dealer at one of the service appointments and they fixed it. I believe they said the panel would not snap back into place because of a build up of road debris underneath when it was loose. They just cleaned it up underneath and it snapped back into place. The cost was minimal if anything.
Old Mar 12, 2021 | 09:14 PM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
I have the same issue... Driver side also... Will not push in. If you have any photos of actual repair, please post.
Old Mar 13, 2021 | 06:59 AM
schack's Avatar
2014 S550
Sorry , no pictures. The repair was performed in the shop area while I was in the waiting area so I didn't actually see what they did. They just told me they cleaned the road debris from underneath so they could snap it back in place. Not sure if they removed the entire trim piece or just pulled back the end in order to clean underneath. The piece is still not perfectly flush but barely noticeable.
Old Mar 17, 2024 | 07:25 PM
BenjaminSimon's Avatar
2004 SL500, 2014 S550
I am having the same issue, but can’t figure out how to snap it back in. Anyone else encounter this?
Old Mar 18, 2024 | 10:51 AM
Barry Hanna's Avatar
'15 E350, '20 S560
I had the same issue on mine (2020 S560) that the dealer repaired. The clip on the front section is different from the rest of the sill and can be tough to just “push in”. I’m only guessing here but I believe my dealer replaced that clip and remounted the sill. It’s a good fix and has stayed put. If you don’t know how to release the clips you can damage the sill and spend $$$ replacing it. As you can see from “Coach K’s” workshop instructions it’s more complicated than it looks if you lack course knowledge. I was certain that if I attempted the fix I would break something as is my normal routine.
Old Mar 18, 2024 | 07:17 PM
Sorry I can't be any more help ... I was at the body shop talking with a guy and mentioned this ... he said they could fix it in just a few minutes and sure enuff it's back where it should be now and looks good again.
Old Mar 19, 2024 | 09:44 AM
'15 E350, '20 S560
Knowledge is power.
