S-Class (W222) 2014-2020
Rotor Pads
Old Mar 28, 2021 | 08:52 PM
Denis Osullivan's Avatar
2018 s560v4
Rotor Pads
When I bought this CPO 2018 S560 I replaced the rotors and pads with genuine Mercedes parts. I did so as I was getting shakes as I braked.
Here it is and the shakes are back. I did a 1600 miles run and the shakes are back. The first 1500 miles were smooth but now they shake like before. Keep in mind that the rotors were replaced just two weeks ago .
Is there a bulletin on these brakes?
Old Mar 28, 2021 | 10:09 PM
MacMP's Avatar
S550 4Matic
Did you do the work yourself?
Did you complete the bedding procedure?
The shaking you feel is almost certainly from not properly bedding your new pads.
Old Mar 28, 2021 | 10:12 PM
2018 s560v4
I’ve done my brakes for the last 40 years and never had such issues. As far as your question regarding bedding I had done so before this highway trip.
Old Mar 28, 2021 | 11:18 PM
chassis's Avatar
2017 GLE350 4MATIC
Did you do the brake work?
Old Mar 28, 2021 | 11:46 PM
2018 s560v4
I did the work. I’ve been doing the brakes on all my cars for the last 40 years. Never had this issue.
Old Mar 29, 2021 | 06:34 AM
ygmn's Avatar
2015 E400 Sedan
ANy bent wheel? or damaged?
Old Mar 29, 2021 | 08:06 AM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
As suggestions, new rotors can be warped. Have them checked for runout. Out of balance wheels can also cause this. Good luck.
Old Mar 29, 2021 | 09:14 AM
DABRONX's Avatar
E55
rotors are not warped.
Ck your driving habits during that last 100 miles. Do you press hard on your brakes after a hot run? Wash car and not drive afterwards? Did you use a torque wrench and an alternative pattern for lug nuts?
The sell pads to hook in a drill t clean your rotors. Do so and see if pulse is alleviated. Find a shop that cuts rotors on car vs off. Use a more aggressive pad to clean up rotors.
Old Mar 29, 2021 | 09:33 AM
Jud Chapin's Avatar
Not sure what you are saying here. Please explain.
Old Mar 29, 2021 | 10:34 AM
MacMP's Avatar
S550 4Matic
The concept of a rotor warping is an old wise tale. Rotors do not warp.
Pad material builds up in places on the rotor if the brakes are not bedded fully, or driving habits cause spotty build up. Then, over time, rotors can wear unevenly.
This is what most often causes shaking while braking (otherwise called warped rotors).
Old Mar 29, 2021 | 10:35 AM
MBNUT1's Avatar
2010 E350 4Matic
Interesting. I certainly have experienced pad material adhering to the rotors after a weekend track session that eventually cleaned up after driving. But they would also tell you not to apply your emergency brake after a track session. I thought the reason would be to prevent rotor warping.
