S-Class (W222) 2014-2020
Door handle lights...
Old Apr 6, 2021 | 03:42 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
So question, should my 2020 S560 have lights behind the door handles? Mine doesn't.
Old Apr 6, 2021 | 04:57 PM
Popo Here's Avatar
2008 S550 4Matic
My 2015 has them but 2 have blown. I'd like to assume your 2020 has them
Old Apr 6, 2021 | 05:52 PM
Sean._.S's Avatar
S550
It's a very common failure on w222's and quite honestly very annoying. When I bought my car, I could tell the both front driver & passenger lights had been replaced as they have a slightly different shade of white. My puddle lamp in the right mirror & rear right door handle light has since gone out... Will be following replacement tutorials online soon.
Old Apr 6, 2021 | 05:53 PM
SW20S's Avatar
2024 S580
Mines brand new, none of the handles have lit up even when it was on the showroom floor.
Did they do away with this feature in the 2018 refresh?
Old Apr 6, 2021 | 06:01 PM
Sean._.S's Avatar
S550
That's quite strange... I think I've seen facelift models with door handle lights.
Just looked up a video and it appears to be on 2018 models.
Old Apr 6, 2021 | 06:19 PM
SW20S's Avatar
2024 S580
I wonder if they're turned off or something...I cant believe all of them would be turned off...
Old Apr 6, 2021 | 06:28 PM
Sean._.S's Avatar
S550
Might be a setting in the updated infotainment system. My system only allows me to set the duration they stay on.
Old Apr 6, 2021 | 06:52 PM
brianc63s's Avatar
c63s coupe, bmw 335i coupe (winterbeater)
Mine are blown on one side on my c63s coupe. Might be off in your settings, also, make sure your lights are switched to auto, because if they are on the “on” switch they will not turn on when you unlock the car
Old Apr 6, 2021 | 10:27 PM
leroysch's Avatar
'20 S450
My '20 S450 has them...functioning even!
Old Apr 7, 2021 | 02:23 PM
SW20S's Avatar
2024 S580
So I gotta figure this out!
Old Apr 7, 2021 | 10:10 PM
Jagbuxx's Avatar
2020 S450 plus 10 others & 2019 Tiffin Phaeton 40AH
same here on my 2020, working
Old Apr 8, 2021 | 12:26 AM
zenderV8's Avatar
S500 4matic L
Obviously I'm as well one of many who fix this issue myself both rear door and both mirror lights .
it is amazing how Lexus manage to fabricate a door light or mirror lights which have lumined over 10 years of daily use !
Old Apr 8, 2021 | 08:54 AM
places's Avatar
No more MB:(
Now I have to check mine. I'm sure you have them, probably just need to figure it out or take it in.
Old Apr 8, 2021 | 11:31 AM
konigstiger's Avatar
'71 Pinto
2020 s5604m VIN EPC shows light (240) grayed out (not equipped) yet 2020 S4504m shows equipped (same bearing bracket) doesn’t make sense. Check your VIN in EPC if you have access if not, PM VIN I’ll check.
Part #s: front left 0998200183, right 0998200283; rear 0998200183, 0998200283
Old Apr 8, 2021 | 12:31 PM
SW20S's Avatar
2024 S580
Interesting...I will PM you the VIN right now
