Similar Experience with Alignment
I'm not sure if any of you experienced the same. So my brand new S560 (car has 1000 miles) was pulling to the driver side for a few days. I called the dealer and made an appointment for the alignment. After picking it up from the dealer, the issue was fixed; however, I noticed that I feel the poles and uneven roads more than before, and the suspension is stiffer. Does anyone know if an incorrect alignment can impact the suspension system or no? Thanks for your input.
b) an alignment that centers the thrust (allows the car to drive straight on a flat road) enables the driver to use less pressure on the steering wheel and sometimes this feels like the car is more responsive (and in some ways it is.)
Alignment is about tire toe-in, toe-out, camber and caster. Without getting into some detail, MB basically allows shop adjustments to toe-in/out. Camber with add on parts can be adjusted. Caster no. For a car with no suspension damage, correct allignment should be a piece of cake assuming TP set at reasonable safe number.
