Correct oil level
Correct oil level
So, just did my first oil change on my 15 S550. Before change, when checking dip stick cold the oil covered the center section of the red plastic to the Max mark. I was able to pump out 6 quarts. Filled back in with 6 quarts and ran the engine for 15 min. then checked the level which didn't quite come up to the max mark so I added additional 1/2 quart. Now this morning I checked the level COLD and it's above MAX and covers the red plastic completely. Checked again after running around town and letting it sit for 15 min. and the level is still covering the plastic. Is this OK or should I remove a half quart?
Also remember that if you overfill the sump the oil will foam up during operation and register at the high point of the stick. If you suspect an overfill situation, let everything cool off, and only then will you have an accurate reading.
First, thanks for the input. My owners manual shows 8.5 quarts including filter. My vac tube did go in further than the dip stick measured and felt like it hit bottom. Thats why I only replaced the 6 quarts I pumped out. I know when you initially remove the dip stick, it's dry and you clean it and replace it then remove for an accurate measure. As I stated, my level is to the top of the red plastic and wondering if it's OK to leave at that level.
What you should do next time is take an extra step. Follow your same method of extraction, then remove drain plug and see how much you are off by. Based on your findings, you will have your answer to continue with extraction method or go with the old drain plug. It is easy to remove the bottom plastic shield to get to the Drain Plug. I believe 8 small screws. It will also allow you to check under the engine for any leaks that may not be visible with the plastic shield installed.
Good Luck!
