S-Class (W222) 2014-2020
2015 S550 Driver side Low beam check error message
Old Sep 13, 2021 | 09:14 PM
ebc1680's Avatar
S550
Hello,
I have a 2015 Mercedes S550 car. Last week I get a error message on the dashboard for " Check Low beam". The driver side low beam does not turn on. The car is garage kept but I had noticed a little moisture in the headlamps but now the moisture is not there. What could be the possible problem and the fix solution to this issue?. Any videos or step by step guidance would be helpful for the fix solution.
Old Sep 13, 2021 | 10:26 PM
MBNUT1's Avatar
2010 E350 4Matic
There are threads in this forum on moisture in the headlights and resultant issues.
Old Sep 15, 2021 | 06:28 PM
ebc1680's Avatar
S550
Thank you for the information. However I would want to clarify and update here that the LED Stripe lights are ON in the headlight assembly unit. Its only the low beam and high beam which do not work and I get the "Check Low beam" error message. I believe that the connector to the headlight unit is working correctly since the stripe lights are working fine. No moisture in the headlamps. Any possible fix or solution to this problem will be greatly appreciated
Old Sep 15, 2021 | 10:14 PM
MBNUT1's Avatar
2010 E350 4Matic
https://mbworld.org/forums/s-class-w...ad-lights.html
