Front Windshield Water Drain
Hi,
I had the water drain that extends from the corner of the front windshield down to near the front wheel well fall out (see picture)? I am going on a couple of long trips now so I really don't have time to get this replaced.
Is this a serious problem? What will happen if I get into rain without this part in place?
Thanks.
Thanks.
I had the same issue as well. I was able to feed it back up from the bottom and reattach it pretty easily. Haven't had any issues since. It did take a bit to figure out where it goes though. There is an opening in the shield under the car where is passes through to drain. It is right behind the wheel. I think I had to loosen a few screws on the underbody panel to be able to get it open enough to push that drain back in place. If i recall right i think it took all of 5 min to fix. I also can't see an issue if you dont put it back either.
Happened to me. Dealer charged me $90 to reinstall as he claimed I hit the underside on something and that’s why it fell out. 2 weeks later it fell out again. Have to waste another trip to get in reinstalled.
