Burmester High End Audio Issue
The warranty should certainly pay for it...
Received 2,711 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
Agree.
OP, dealerships usually scare people with a diagnostic fee (mostly because then they don't have to fix your issue if you don't agree and there is no clear sign that it is a defect by just a visual or computer inspection (ie. no codes), this is especially common since they are short staffed) but if you know that you didn't damage it yourself by any means then warranty should cover it. Once they actually do the diagnostic and determined that it is a warranty issue, the warranty will cover the diagnostic fee as well.
Are you still within the factory new car warranty? If so, it should absolutely be covered. This “not sure it will be covered” business is absolutely nonsense and a waste of your time.
Take it to another MB dealership if possible.
Basically the dealer just doesn't want to mess with it...
steinjr (01-11-2022)
Received 4,446 Likes
'71 Pinto
#32
Thank you all for your replies. This is an aftermarket warranty through Assurant. It's their Hi-Tech warranty that also covers electronics.
ELECTRONIC HIGH TECH COMPONENTS
Level control compressor, sensors and limiter valve;
pneumatic suspension pump sensors and valves; fuel
injection sensors and control module; ignition module;
crank sensors; digital or analog instrument cluster;
moisture control unit and sensors; anti-detonation
sensors; manufacturer installed combination
entry system; manufacturer installed anti-theft
device; ABS (anti-locking braking system), electronic
brake control module.
ELECTRICAL PLUS
All power motors and solenoids related to the electrical
operations of antennas, door locks, power
headlight motors, seat motors, mirrors, convertible
tops, power trunk releases.
FACTORY-INSTALLED NAVIGATIONAL SYSTEM
Display, controls, and all electrical components.
ELECTRICAL
Alternator; voltage regulator; voltage sensor; distributor;
starter motor, starter drive and solenoid; electronic
ignition module; wiring harnesses; manually operated
switches; wiper motor; power window motor; sunroof
motor.
ELECTRICAL PLUS
ELECTRICAL
motor.
