S-Class (W222) 2014-2020
Ignition Coil
Old Jan 14, 2022 | 10:53 PM
604benz's Avatar
2015 S550V
Ignition Coil
Hi Guys,
I had my check engine light come on and pulled codes P0301 and P0351, looks like io need to change cylinder 1 coil, all the local parts stores and dealerships have this part on backorder, i even tried FCP Euro and they also have it on backorder, the only place i could find them was on eBay from China which i don't want to purchase from.
Does anyone on here know of any places i can order from online that has in stock
Old Jan 16, 2022 | 09:41 AM
chassis's Avatar
2017 GLE350 4MATIC
How did you conclude the coil needs to be changed? Read about misfires with the M278 engine. There can be other reasons for misfire: oil in engine harness and cylinder scoring to name two. Have you done other diagnostic tests including inspecting cam position harness connectors, compression and using a borescope on cylinder #1?
There is a long list of part number successions (replacements) on ignition coils, not surprisingly for MB. MB revises part number, often because of realizing they have a problem and are attempting a fix.
Have a look through mbepc.net and see if you can find a valid part number for your engine, then search for a vendor with it in stock. But do the diagnostic work first (inspect for oil on electrical connectors, compression, borescope).
Old Jun 14, 2022 | 12:20 PM
Blackrain's Avatar
2016 S550, e39 M5
Getting the same code. I would love to hear how this turned out, be it a positive or negative outcome.
Old Jun 14, 2022 | 04:06 PM
604benz's Avatar
2015 S550V
Hey
Yes i kept getting that code with rough idle, changed the coil and have not had that issue since then
Old Jun 14, 2022 | 08:47 PM
Blackrain's Avatar
2016 S550, e39 M5
Thank you very much. New coil on the way. I will post back if it fixes the problem.
Old Jun 21, 2022 | 10:54 AM
Blackrain's Avatar
2016 S550, e39 M5
National Backorder prevented me from getting the original OEM coil for a 2016 S550. After some searching, I got a match from Parts Express. I replaced the coil, it cleared both coil faults, turned off the check engine light, and now the engine is purring like a Kitten again. A Siberian Tiger Kitten, but you get the point. Part number:
​​​​​​0221604034 Bosch
Old Jun 21, 2022 | 01:06 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Congrats on your successful solution. With diagnostic labor in the hundreds per hour a little part-changing is a reasonable first thing to try ... btw, Rock Auto purports to have these for $42 ea ...
https://www.rockauto.com/en/moreinfo...2BAkajlRCfbbjv
