S-Class (W222) 2014-2020
W222 M176 Limp/Safe mode?
Old May 14, 2022 | 05:11 PM
petercbkk's Avatar
W221 W222 S560e w222 S560
Exclamation W222 M176 Limp/Safe mode?
The engine just cuts out at 3.5K Rpm all the boost is pushed out as well making a woosh noise
another code came up
Rader sensor dirty and Engine oil level cannot be measured
Check engine light is on
these are the code
How can it be so many shorts to the ground?
s on XENTRY
Old May 15, 2022 | 07:29 AM
Senecat's Avatar
1983 Nissan Shltbox
Someone forgot to bolt a ground back to the chassis or connect a harness plug somewhere. Take it back to whoever you just took it to to have work done to it.
Old May 28, 2022 | 11:24 PM
petercbkk's Avatar
Alright thanks, i’ll try that let’s see what happens ! 😊
Old Jun 3, 2022 | 12:56 AM
petercbkk's Avatar
it’s fixed was just an ECU short circuit so had that fixed 😀
